205 in place of an 83 208 with 465 tranny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Mar 26, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    will an adapter be needed to put in a 205 in place of a 208 in an 83 with 465 ? anything else ? if this 83 465 tranny has 32 spline then will a th400 205 case work on the 465 ?
    searching forum right now
    thanks
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: 205 in place of an 83 205 with 465 tranny
    you might want to change the title...it says change a 205 to a 205 /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/rotfl.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    208 to 205
    thanks
  4. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    What did the 205 come out of? Does it use a figure 8 or round bolt pattern adapter? I'm pretty sure that the 465 will have a long 32 spline tailshaft (since it was originally mated to a 208).
    **Assuming it's a figure 8 style 205** I think you can put the 205 on the 465 using a 4 spd adapter and a short 32 spline female input shaft (like a TH400 application). Never actually tried it but I measured the parts one time and it would be VERY close to working.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    how do i tell what shape adapter with everything installed in truck ? and what happens if its round ? is round earleir or later, what about figure 8 ?
    thanks
  6. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    The figure 8 is pre-85 and the round adapter is 85 on.
    I guess the easiest way to tell the difference in the truck would be the t-case crossmember. The figure 8 adapter is tall so the crossmember is flat all the way across. The round adapter is shorter so it uses the " W " shaped crossmember.
    If you need pics I have both style adapters and crossmembers at home.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    awesome, thats enbough info right there, ill have to go look under truck real quick again, its across town, thanks, i take it i should hope for figure 8 if i want to put in a 205, right ?
    thanks
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its got straight across one, so can i get a 205 in it and if so then what one ?
    thanks /forums/images/graemlins/laugh.gif
  9. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    If you talking about what 205 the easiest to put in it would be a pre-85 TH400 case but those aren't exactly lying around. Any GM 205 can be converted to the 32 spline input so really I'd say find the cheapest one around (4spd maybe?).
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    apparently i just need any pre-85 205 off a 465, cant beat that ! /forums/images/graemlins/thumb.gif
