205/ Input shaft/gear
Discussion in 'Parts & Trucks Wanted' started by Don, Apr 28, 2003.
  1. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Doe's anyone have an input gear for a 205? 32 spline for a TH400?? /forums/images/graemlins/eek.gif How much is it gonna set Me back? /forums/images/graemlins/eek.gif
  2. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I purchased a brand new one for just over a hundred dollars, if that gives you any idea on what a used one is worth.
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Are you converting from a different spline? If so the case will need to be bored for the larger bearing. You can buy the conversion kit from ORD for $200.00. You get a 32 spline input gear, front bearing, and a gasket/seal kit.
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I've read that and was just wondering. I suppose if You add in the machine shop labor, to bore the case to accept the larger bearing, it would just be easier/cheaper to find a 400 case for the 205? /forums/images/graemlins/eek.gif
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    You can also buy a completely rebuilt 205 from ORD that already has the 32 spline input and whatever spline front output you want for 850.00 plus shipping.
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if you need the 32 spline long input i have one for 50 plus the ride.
    but i doubt you do.
    grant
