205 input shaft
Discussion in 'The Garage' started by 454k30, Aug 26, 2005.
  1. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I purchased an NP205 with the 10 spline input to rebuild and turn into a 32 spline case for my doubler project. When I got it home and started running it through its gears I noticed that the input shaft slides out about 3/8 of an inch. it still turns when the shaft is slid out but makes an odd grinding sound. What problem do I have here if any? Thanks guys!
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Do you have the adapter on it? If not, the bearing will not be retained to the case, therefore allowing the input shaft to "walk" out.
  3. 454k30
    Sep 13, 2004
    1,613
    California, MD
    no
    No there is no adapter installed just the plane jane np205 case. So this thing sliding out a little ways is normal???
  4. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    yes
  5. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    the input bearing should have a big clip that keeps it from falling in to the case. the clip and bearring is sandwiched between the adapter and the case in the grove of the adapter see the pic
    when you pull it forward the gear inside is probably rubbing the inside of the case
