205 keeps popping out of gear!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Batmanjr, Nov 10, 2003.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    Copperas Cove, Texas
    Will a rebuild fix the problem, or em I most likely going to have to find new hard parts? A 205 around here is like $200, a rebuild is like $100.... Then hard parts to boot! It won't go into 4hi unless I hold it, and it pops right out of 2hi sometimes! It's pissing me off, cause it's like the only thing I didn't rebuild when I put this truck back together and left it to chance! Murphy's law I guess!
  2. FWP
    Oct 11, 2000
    Prescott Valley, AZ
    Check a few easy things first, like the shifter mech. Make sure it's not binding up, moving, adjusted incorrectly or otherwise causing a problem. You can even disconnect the linkage at the case and drive it to see if it is linkage related. If it pops out of gear with the linkage disconnected, pull off the road, shift it back in by hand. If it works good, you know for sure it's in the linkage. I had to do this on my doubler, 203 side.....Turned out to be the 203 /forums/images/graemlins/frown.gif
