205 part number(s) request
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dyeager535, Jul 14, 2003.
  1. dyeager535
    26,982
    191
    Last post for this issue, I swear!
    Still can't get the later NP205 4wd indicator switch to work with this 70's 205. Think they changed the shift rail(s).
    Can anyone provide me the part numbers from a 1970's GM parts manual for the NP205 shift rails?
  2. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    14022221 Shaft, Front wheel shift
    6259153 Shaft, Rear wheel shift
    Source: 1973-1978 Truck Parts Catalog
    Series 10 Thru 35
    Effective February 1984
  3. dyeager535
    26,982
    191
    Sincerely appreciate it, but unfortunately, they are exactly the same piece.
    Can't figure this out, only difference I can think of now is the case, (15591398 for '85-86) or the ball bearing poppet plug ball (5/16") changed size.
    FWIW, you can't just change the spring to make it easier to shift gears, that only affects one half of the shifting mechanism. Doesn't enough difference that would allow the 208 shifter to work.
