205 part swapability... if thats a word.
Discussion in 'OffRoad Design' started by Seventy4Blazer, Jan 17, 2003.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    ok, i have 3 NP205's
    all are diferent.
    one is a 10 spline input with a u join yolk at the rear output.
    one is a th400 long 32 spline input with a slip yolk as the output.
    the other is a for, unknow slpine count u joint output.
    the th400 version needs the case taped out for the doubler addaptor. that i can do. can i put the ford input into the th400 version and then use the 10 spline version parts as a SYE kit?
    Grant
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    yes on swapping the inputs , i dono on the output but i dont see why u couldnt .
  3. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i know i can for the rear, but i wanted to double check.
    thanks andy.
    isnt the ford input a 31 spline?
    my main question for steve is will it mean a custom shaft for between them.
    grant
  4. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    yeah i think your right the ford is 31 spline . what i did was bought a th400 input gear <short> $160 or so from ORD and it fits perfectly in the ford 205 that i am going to use . so it look like you need a short th400 input huh ?
  5. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah, but if i can save 160 dollars then i can put 160 dollars into something else.
    i would think that they could come up with something just by mixing parts, hopefully steve sees these soon so i can find out and start on the prodject.
    Grant
  6. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    how about you bring the th400 input and while you are tearing out the wire harness ill turn down / shorten the input gear /forums/images/graemlins/thumb.gif
  7. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    now thats not a bad idea... why didnt you think of that earlier.
    would next weekend be good?
    or thursday evening of this week? like say about 6 pm your time.
    Grant
  8. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    you could bore out the case i have that has the 10 spline input as well could you not?
    grant
  9. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    now why didny you think of that earlier ! /forums/images/graemlins/rotfl.gif yes i can do that too . /forums/images/graemlins/deal.gif
  10. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    ill need both done ethier way. when is a good time and i am assuming that i will need a new input bearing for fit and all?
    grant
  11. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    how about this weekend ? and yes ill need a new bearing to mic.
  12. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    k, ill get a bearing. this weekend will be fine, as of now. i dont foresee a reason why not. ill kee you updated.
    got a part number on that bearing? ill do a seardh for it and all. but if you got one then GREAT.
    Grant
  13. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    i might be playing paintball sat morn -aft otherwise all clear .
  14. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    THATS COOL MAN.. damn caps key.
    i got to find a bearing first.
    found a few but the prices are BAD.
    i got the 10 spline case all torn appart. i just need to remove the shifter forks.
    maybe ill find a rebuild kit and go that way.
    i am going to tear the other case appart tonight.
    grant
  15. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    do you have the box from your bearing? or can you still see the part number?
    if so can i get it. thanks. grant
  16. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    no i never got a new bearing /forums/images/graemlins/ignore.gif / yet .
  17. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    ok, good news. no need for any machine work. i can use the round style case that has the long input with the ford input in it. then they just ship me a ford conector shaft and a chevy adaptor. problem solved. now i have to put the SM465 model transfercase back together and tear the other two appart...
    oh well.
    thanks a lot andy, and i still would like that harness. im just not sure if this weekend is going to be good.
    ill keep you updated.
    grant
  18. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    Just to clarify what this is about:
    He had a round pattern NP205 with the long 32 spline input gear from a '85-'91 1-ton with a TH400 or SM465. To use this case with a Doubler kit, you need to swap in the short 32 spline input gear. It's a direct bolt it, the case has the correct size input hole already. We build an adapter to bolt directly to the round pattern NP205 bolt face with no other mods required.
    And it's not a big deal to send a kit with a 31 spline shaft instead of a 32 spline. It's a little odd but no reason it wouldn't work.
    You can't shorten the long 32 spline input gear or you'll cut off all the splines, so that technique won't work.
