205 Pto
Discussion in 'The Garage' started by broc944, Feb 24, 2006.
  1. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    I have a 205 that has a PTO. Exactly how do you control the PTO function? If anyone has an exploded parts view of the PTO I would greatly appreciate a copy.
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    the PTO should have an input that you can make cable or linkage driven. then a lever wherever you want it. you should be able to find PTO cables on the net real easy.
    see if there is any info on the PTO unit then do a search for it online. should be able to find the specs of the PTO and if you can find a maker thats the place to find a cable or linkage setup.
  3. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    The PTO would only work if the transmisison was in gear on this application right. I know if it was on the trans it would work even in neutral. Not sure about how this is driven though?
