205 Q's (adaptor info!)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by skyyk5, Jan 21, 2007.
  1. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    so the adaptor for the round 205 is the same as the 208/241 for the sm465? i just read it somewhere. and the 205 for the th400 has a shorter input then the 205 for the 32spline sm465? read that too. just want to check make sure it is correct.
  2. dyeager535
    26,982
    191
    The bolt pattern may be the same, but the adapter is not.
  3. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    different lenght? i though so. just thought i'd ask. thanks
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Actually the length is the same, but the 208 adapter doesn't have the mount for a shifter.
  5. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Actually, the length is different:
    sm465 to round Np205 adapter is 10 inches long
    sm465 to NP208/241 adapter is 8.5 inches long, no shifter boss
    sm465 to figure 8 NP205 adapter is 8 inches long
    TH350 to figure 8 NP205 adapter is 3.5 inches long
    TH400 to figure 8 NP205 adapter is 4 inches long
    TH400 to round NP205 adapter is 4 inches long
    4L80E to round NP205 adapter is (I think) 4 7/8 inches long--I've never seen one in real life.
    Also to note here is the round adapters are shorter than the figure eight adapters, and therefore use either the single or double hump crossmember, whereas the figure eight or tall adapter uses the (relatively) flat crossmember.
    Jimbo
  6. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    i love the info that is shared here. as always thanks for all the help, and info.
  7. cveklund
    cveklund Registered Member
    Oct 21, 2006
    9
    League City, Texas
    If I have a 205 with a th350 and want to replace the th350 with a th400, would it bolt up or do i need some sort of adapter?
    Thanks,
    Chris
  8. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    this i know. different adaptor and the input of a 350 is 27 spline and the 400 is 32 spline. gotta change inputs too.
  9. cveklund
    Oct 21, 2006
    9
    League City, Texas
    How much work is involved in that and where would I get the parts? Sounds like a pain in the butt.
  10. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    unless you search and find the adaptor bearing for the 27 to 32 input swap. you will need to machine the case for the bigger bearing.
  11. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    easy way is to find a 205 and adaptor for the 400. i'm sure you can find, buy, or trade here. just post it.
  12. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    :bow: i forgot to say that:bow:
    i gotta do it myself soon
  13. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    Adapter info updated.
    Jimbo
