205 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mr.Chevy4x4, Dec 6, 2001.
  1. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Shift shaft seal replacement. How hard is it, and can it be done externally?
    And as always, I'll be a thankin ya! [​IMG]
    '85 K5 : Run it til it breaks, then fix it and go again!
  2. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    No. The shift rails will need to be removed. Sorry
    MAC
  3. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    so that is a full disassembly?
  4. RGF
    RGF 1/2 ton status
    Jan 5, 2001
    281
    Maine
    Shaft seals can be done without full disassemble but is a pain, but so isnt pulling the transfer and tearing it down because of that little leaky seal. Pull the bar from the rails and carefully dig them out without scaring anything up, I think I used one of those cheap bodyshop slide hammers before after drilling a small hole in the old seal. Slide the new one on with some grease on it and come up with a small pc. of pipe that will drive the new seal on but has ID bigger than the shift rail and tap it in.
    RGF
  5. 4xmac
    May 1, 2000
    82
    Calif. Oceanside
    Good idea RGF, I hadn"t thought of that.
    MAC
