205 Question
Discussion in 'The Garage' started by Swanson52, Sep 8, 2002.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Ok, the whole 'this 205 fits that trans with this adapter' and all off the different applications are lost on me. Never paid that much attention, I guess. Anyway, here is my query-I just got a 205 out of a 73 Chevy truck that was bolted to a TH350. Is fitting this to my 85 T400 the same procedure as fitting my 79 465 version 205? I will assume I still need the 400/205 adapter? Just making sure. Thanks.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    To answer your PM you sent me, there are a few different spline counts on the 205's.
    10 spline fit the 465 trannys.
    27 spline fits the 350, 700R4, and 4L60E trannys.
    32 spline fit the 400, 4L80E, and '81 & newer 465 trannys.
  3. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Thanks. I was a little bleary-eyed when I logged on this morning and accidentally deleted your PM.
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    That t-case (205 mated to a 350) can be used and bolted to a 400, BUT you will need the 400/205 adapter, the correct 400 input shaft for the 205, and the case machined to accept the larger bearing used in 400 versions of the 205. You might be able to sell that one and buy the correct one (less hassle) or even arrange a swap with somebody who needs what you have and has what you need.
    This will also help explain what I'm trying to say.
    www.offroaddesign.com/NP205tech.htm
    www.offroaddesign.com/transfercaseparts.htm
