205 Questions?
Discussion in 'The Garage' started by 84 K5 4x4, Mar 4, 2007.
  1. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    Is a 10 spline front output shaft the same size as a 30 spline? Or in other words I'm swapping from 10 spline to 30 spline and can i use the same bearing and gears or do i have to change anything?
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    IIRC just swap over your bearing and install the new shaft.
  3. 84 K5 4x4
    Nov 14, 2006
    163
    Jasper Ga
    I got the new shaft from a donar case and the bearing is shot.
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    So swap your bearing onto the donor shaft and install in your case.
  5. 84 K5 4x4
    Nov 14, 2006
    163
    Jasper Ga
