205 removal
Discussion in 'The Garage' started by 69K5, Dec 14, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    how hard is it to yank off a 205 with it still under the truck. ive never actually dropped the tranny onthe blazer just slid it back to change the flywheel. trying to save some bench pressing weight.
    ill probably slide it back and take off the tc if theres room as well
    thanks
    69k5
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    floor jack with tranny adapter cradle would be the best, or chain the piss out of the case to the floor jack pad
  3. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    if u have a tranny jack or something it shouldnt be too bad. I dont care how much u can bench, whatever you do dont remove it by yourself in the "bench press" position. that sucker is fawkin heavy, awkward and just begging to crush some poor saps skull!
    j
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i have a 3 ton hydraulic jack. so looks like ill have to chain it to it. im not gonna try to bench press it by the way. it was meabt as a joke. /forums/images/graemlins/grin.gif i spend too much time in the re as it is. /forums/images/graemlins/grin.gif
    69k5
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Definately use a floor jack it you have access to one. I have done the bench pressing method, and I don't recommend it. /forums/images/graemlins/eek.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    With fluid, it weighs about 225lbs and is way akward. /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    225 #'s that aint nothin. I could do it with my pinkies /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    oh yeah how many bolts am i diggin through the mud to get to??
  7. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The weight isn't the problem....it is just a teenzy bit harder to hang on to than a 45lb bar. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
    ...and then get the splines lined up, inserted, and start the bolts with your "free" hand....since you are only using your "pinkies" /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    45 lb bar??? please I have to use the 15 lb bar. its just my pinkies that are that strong
  9. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    do it when it's really cold out... /forums/images/graemlins/blush.gif
    So you feel no pain... /forums/images/graemlins/thumb.gif
    Damn things are heavy... /forums/images/graemlins/rolleyes.gif
    not as bad as a 203 though.../forums/images/graemlins/deal.gif
  10. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    LOL!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  11. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    not as bad as a 203 though... /forums/images/graemlins/deal.gif
    I will have to agree with you on this one, the 203 is a 500 lb boat anchor /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  12. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    When I dropped mine to rebuild the th350 I dropped the 205 first. I did it with a tranny jack and a floor jack. I was on one side balancing the cross member and working the tranny jack while a friend was on the other side with the floor jack and also balancing. Would be nice if there was a single flat spot in the bottom /forums/images/graemlins/mad.gif When I put it back in I used a cherry picker with a chain wrapped around the adapter (just happed to be the balance point) and it was ALOT EASIER!
