205 right side brace
Discussion in 'The Garage' started by original balzer, Jan 31, 2005.
  1. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    with the 205 transfercase, there a bracket that goes on the right side that bolts to the frame rail to control movment, it's not there on 77 and later trucks, but i would like to see one if anyone has pics i do from time to time get a thump from the x-case hitting the floor in the back ( i know i know replace your worn out body bushings right) so i would like to make or instal this brace
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    me too... i dont have anything connected to my 205 there rither...
    j
  3. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    you mean this?
  4. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Hey I own that now :D:D
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Here are two pics of my factory bracket:
  6. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    THANKS BEAST388 thats the kind of pics i like to see . now i have a much better idea how to make my own setup
  7. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Anytime!:waytogo: :saweet: :thumb:
  8. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Here is another one:
  9. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    wow cool, have to make one of them. I got some spare leaf spring bushings laying around, I'll prolly just set one up with that. Thanks for the pics. Does not having that brace tend to lead to anything bad? I have never had it on my K5, but I havent beat on my rig toooo much since I installed the 205. Then again.. I have had a problem during high torque output on my rig... it sounded like the 205 was slipping out of 4 low, sort of a loud grind gears-not-meshing sound. Really nasty. Anyway, maybe the real problem was the case was tweakin' cause it didn't have the extra support it needs....
    j
  10. AkMudr
    Dec 30, 2004
    917
    Alaska
    Its hard to say what can happen without the side bracket. Ive seen busted/cracked adapters...theres alot of factors involved, torque, hi/lo range, terrain, flex and more. But, one reason I decided to use the side bracket was because the tcase itself is 134lbs, and none of that weight is directly supported..yeh...yuo have the crossmember, BUT, the crossmember does not bolt directly to it. IMHO there needs to be some kind of vertical support ..that much weight bouncing around does nothin good in my book.
    One thing to consider is that by using the bracket, you do limit the cases ability to freely rotate however many degrees under a load of torque. With that said, it is best to use the same material bushings all around to give each drivetrain component the same amount of "give"
    My .02.
  11. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    WAIT! My 205 has this big rod that bolts onto it's side and goes up to the engine and connects to it?! Well, my wife's does anyways, mine doesn't have anything there.
    I like that bracket idea. Where can I get one? I've always felt a little nervous about my 205 not having a brace there.
  12. AkMudr
    Dec 30, 2004
    917
    Alaska
    Chevy used the side bracket in the early 70's then later went to the rod brace, then later used nothing. I guess its just a personal preference...mroe of a "What you think is best for yer rig" type of thing. I personally dont wanna **** up $1000 in new drivetrain over some bracket I coulda used in the first place.
    You'll hafta really look around inthe junk yards for it. Ive spent a lil tiem on the net lookin for one and I didnt find it til I came here. Check around, I'm sure someone here has a complete setup layin around...remember..its a 3 piece setup. Or, if you had the time you could make it using angle iron.
    My .02
