205 shifter and body lift question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mpascino, Jan 2, 2002.
  1. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Hey guys, I noticed when putting my 205 in that the shifter hits the body and won't allow it into 4 lo. This is because the fact that the shift only sticks 2-3 inches through the floor because of the body lift and the throw is off because of it. Any suggestions on what to do rather than """relieve""" the body? I would like to use the stock 205 or similar boot over the shifter hole. I know I need to extend the shift. Thanks,
    Mike
    The jeep eater ......[​IMG]
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Either "relieve" the body or remove the body lift, unless you can magically move your t-case up the 3" and deal with driveline angles, which is highly unlikely.
    I'd use a 208/241 boot to make it look somewhat stock.
    Tim
  3. mpascino
    Jan 1, 2001
    557
    Connecticut
    I guess it's a done deal, thanks.
    Mike
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    When I put in the 700r4 in place of the TH350, I had a similar problem but I was unable to get it into 4hi instead of 4low (it was set too far back). Instead of relieving the body, I cut the top of the shifter, welded a plate (for an offset) and rewelded the top of the handle (rod part) so that it sticks up through the stock boot in the stock location (or pretty darn close to it). I did it in such a way that I can grind the welds, take the offset piece out, and reweld the rod on like it was stock if I decide to go back to a different configuration.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
