205 shifter bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Oct 4, 2002.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    The threads on this thing are an odd size. Anybody know where I could look to get a bolt SIMULAR to this that I can modify to accomodate twin sticks? I have tried Fastenal with no luck. I may end up retapping a larger bolt or the hole in the case or both if I can't find something that'll work. Any other suggestions?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well personnaly I just used this bolt along with 2 others on the trans and xcase, to bolt a flange I made and I made a complete twin stick from scratch.
    One thing though, I heard you can remove something inside the csae so you can have front wheel drive only but I can't find in which issue of four wheeler I read this.
    Anyone know how to do this?
    IceMan
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Go to your local GM dealership and tell the parts man you want part number #14009313. Expect to pay around $15 for the bolt. /forums/images/graemlins/wink.gif
  4. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Yea I've done this all ready. You gotta grind in a couple spots on the left side shift rail. I was just thinking I could try and find a bolt with a 3" shoulder for the two sticks to pivot on. You have any pics of your set up/linkage and stuff? Guess I could buy another bolt from GM and cut both of them in half and weld them together.
