205 shifter/ what size bolt?
Discussion in 'The Garage' started by supersize75k5, Sep 17, 2006.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I am talking about the bolt that goes through the shifter and gets greased,
    looks like a 9/16, or some type of threaded rod with a retainer clip?
    :dunno: :1zhelp:
    maybe I am over complicating this
  2. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    I'm pretty sure it's 5/8 coarse thread. I'll check later this afternoon, and I might have an extra.
    Jimbo
  3. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    ill peek at my stuff too. i should have en extra stocker layin around. its not quite a regular bolt. the shank is a good bit thicker than the threads.
  4. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    they changed a few times..
    The bolt in my 74 K20's NP205 that broke off IN the adapter was a special shouldered bolt that had a 1/2" shank and either 3/8 or 7/16" thread! (I forget,it was 5 years ago when it snapped)..nothing worse than trying to shift into 4wd on a snowy day,and have the shifter drop down to the boot,and do NOTHING when you shift it!..:doah:
    After searching 3 boneyards for another bolt,I discovered other years had different bolts and adapters..so I ended up drilling the busted bolt out after yanking the "tunnel" cover up,and I re-tapped it for a 1/2" bolt,and used a nut on the threaded end to take up the "end play"..I also used a needle bearing I found in my junk drawer that fit perfect in the shifter,and had a 1/2" bore..I never forced the shifter after that!..
    I still thought the bolt alone was a bit wimpy...it should have some kind of a brace under its head bolted somewhere, to resist side thrust on it..GM goofed thinking a bolt alone would be sufficient..especially a shouldered one with dinky threads...:mad:
  5. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    thanks guys
  6. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    Do you still need one? I finally remembered to look and found an extra.
    Jimbo
  7. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    nope but thanks, I did get one,
    also what a weird bolt!
    -shawn
