205 slipyoke stats
Discussion in 'The Garage' started by rcurrier44, Sep 15, 2005.
  1. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    I am puting together a truck for a winter DD and summer camping rig. I have a 80 3/4 ton long box with the sm465/205/rear slipyoke to use. It will be running 33's or maybe 35's with a 56" spring/shackle flip rear suspension.
    I haven't messed with a slip yoke case before.
    What is the usable slipyoke travil? What drive shaft angle/lift height would you say I should stay under? I can run a limiting strap if necesary.
    ROB
  2. rcurrier44
    Oct 13, 2003
    320
    ttt
    ttt
  3. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I'm using about 5.5" of lift in the back and have had no problems. I did tilt the case down a little, maybe 3/4", to cure some vibes. No travel issues, but I don't jump my truck, so I doubt both rear wheels get stuffed or drooped at the same time.
  4. rcurrier44
    Oct 13, 2003
    320
    I assume its in your 80 GMC??? Is that a long box too?
