205 Speedo gear help
Discussion in 'The Garage' started by FWP, Oct 23, 2002.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I took the rear output housing off the case because the speedo wasn't turning. All teeth on both drive and driven gears are in good shape...... I can't tell what the heck would be wrong.... What keeps the speedo drive gear from spinning on the output shaft, just the pressure from the yoke nut? Any ideas? /forums/images/graemlins/1zhelp.gif
  2. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    Have you checked the cable? Is there a ratio adapter between the cable and 205? If the gears are OK in the 205 then 1 of these are the problem. Hope this helps.
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    ditch it! /forums/images/graemlins/eek.gif.... speedo's are overrated /forums/images/graemlins/pimp1.gif
    Marv
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Hey... be quiet you... your truck isn't streetable by any........ /forums/images/graemlins/rotfl.gif
    ....Bootie fab.....
    Oh, BTW, I figured it out, it works now /forums/images/graemlins/grin.gif
  5. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    If you ditch the Speedo, your nads will be haning out in the wind, DUDE, you are brave to ditch the Speedo, swimming neked it's just not for me!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    What's a speedo, OH MY GOSH, it was that thing that got in the way of the doubler, you mean I shound not have cut that thing off with a set of bolt cutters!! /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    YOU DON'T NEED NO STINKING SPEEDO!!! /forums/images/graemlins/pimp1.gif
    (CB ECHO ON) BOOOOOTIEEEEEE FABBBBBB (CB ECHO OFF)
    Finished the rear disc conversion on the blazer tonite!! BOOTIE FAB!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
    (Bow down mode on) FRED WE ARE NOT WORTHYYYYY (Bow down mode off). /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  6. khotmer
    khotmer 1/2 ton status
    Oct 23, 2002
    228
    columbus, oh
    i had this problem and found that the cable housing was sitting on the exhaust pipe and melted....when it cooled it sealed around the cable keeping the cable from moving. replaced the cable and housing ...tied it so that it would not touch the darn exhaust pipe and all is well....
    may or may not be you case but thought it might help.....
