205 stuck in 4 lo
Discussion in 'The Garage' started by nose60, Feb 17, 2005.
  1. nose60
    nose60 Registered Member
    Apr 5, 2004
    7
    Fallon Nv
    :confused: WTF I was checking this thing out after instaling the shifter and it is now stuck in 4 lo I have heard of this before how do u get it unstuck?
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Have you tried unlocking the front hubs? Sometimes you have to really yank on the shifter.
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I've had that happen before, seems like it always helped to unlock the hubs and back up just a little, and try to pull it out while SLOWLY coming to a stop. This is with a manual though. If you're auto, you probably want to do this in nuetral.
  4. nose60
    Apr 5, 2004
    7
    Fallon Nv
    the front drive shaft is out I am swaping th 350 203 to sm465 205 in a 79 k5 has gone smooth untill now
  5. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    I would suggest looking at the shifter since you just installed it. Something there has to be wrong or a part missing (sorry).
    Until you can diagnose the shifter issue you could get under it and disconnect the shifter from the case and manually work the shift rails (with a pry bar, etc.) to get it out of low.
  6. nose60
    Apr 5, 2004
    7
    Fallon Nv
    pry bar bent :mad: I will have to try after I get it moving thanks guys. guess I will not have to worry about it popin out like the 203 :grin:
  7. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    eew... are you sure the 205 was ok before you installed it?
  8. nose60
    Apr 5, 2004
    7
    Fallon Nv
    drove the doner truck home got it from a friend worked last time we went weelin
  9. poinzey
    poinzey 1/2 ton status
    Jun 16, 2004
    113
    Texas
    Don't know if this'll help or not but I have to be rolling forward very slowly to get mine out of 4lo. Usually takes a few tries to get it to shift.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I do the same, with lockers they often bind up quite hard.
    Back up and pull forward while pushing forward on the shifter...it'll usually come out.
  11. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    For those that missed this part...
  12. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Get a big hammer...
  13. poinzey
    Jun 16, 2004
    113
    Texas
    My bad on missing the front driveshaft part, but you may need to turn the front yolk to get the gears to mesh, might take two ppls. from what i understand, these boxes aint synchod so if the gears dont line up it aint shiftin.
  14. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    mine is tough to shift too...
    I have to either back up or go forward quickly(punch it!)and then yank on the lever while you let off the gas--its due to the axles binding up,usually from being on tar instead of a slippery surface--I've got it down to a science now,when I first put in my NP205 I thought it was trashed,since I bought it from a boneyard,and found it in the back of an old P series bread van,they didnt know what it came out of,or if it was any good--I had to pay 150 bucks for it too,it was the only one available at the time--It works good though,just a pain to shift sometimes..:crazy:
  15. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    mines the same way,somtimes u get lucky and it will go,other time takes a foot or two,im runnin 4.11s in the frnt and 4.10s in the rear, usually it goes in after i put it in neutral and rock it,if i had too
  16. nose60
    Apr 5, 2004
    7
    Fallon Nv
    Big Hammer worked
    When all else fails get a bigger hammer. I tried rocking it after it was all together no worky. I had to remove the rear cover and use a punch and hammer all works well now:grin: . I think someone(one of 3 son's 4 year old with hammers) jamed the front shift pin when it was on the garage floor. Darn yard ape's:crazy: . thanks for all the input. :laugh: (shackle flip 4" lift next):laugh:
  17. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    Mine will bind up in 4lo. I roll the truck forward and back pulling backward on the t-case handle while I do it. Sometimes a quick blip of throttle while in reverse will allow me to get her out of 4 lo as well.
  18. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    I have the same problem when trying to get back to 2wd, I know when I put it in 4lo I have to be in park and my foot can't be on the brake. but to take it out and go to 2wd I have to be in Nuetral with the hubs unlocked and my foot off the brake. It's stiff but once it's out of 4lo it is smooth.
    I would just try to rock the vehicle back and forth a few feet and try again, it could be in a bind? Good luck
