205 T-case and 700R4??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sapper, Sep 4, 2001.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Been thinking about tradeing the 241 for a 205. Do i need any kind of adaptors for this?
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
  2. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Pretty sure you have to get a short output shaft put in the 700R4, which involves tearing the whole tranny apart. I have thought about it before, just not worth the hassle to me.
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  3. sapper
    Jul 11, 2001
    3,052
    NoVa
    that wouild be worth the hassel. i need to rebuild the tranny too.
  4. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Yes, you will need an adapter. They are available from Advance Adapters.
    They are pricey.
    Lift It, Lock It, LIVE IT!!!
  5. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    This is what you will need: a short shaft from advance adapters, a 205 from a TH350, with the adapter, and probably the crossmember that came with the tranny/t-case combo. I did this swap a few years ago, and by far the most time consuming part was dropping the tranny to get the short shaft installed.
    BIGJ
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    NP 205 from TH 350 is going to be hard to find. Around where I live, impossible to find. Good luck.
    Tim
  7. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    why do you have to have a 205 xfer case from a th350
    my 700r has a 205 in it, or is this something that a previous owner changed?
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  8. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    If you have a 205 behind a 700r4 it is not factory. Your 89 should have a 241 t case.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  9. BIGJ
    896
    Central Arkansas
    The th350 has a 27 spline output I believe, and that matches the 700r4. That isn't the only option, just the easiest. You could always change the input gear in the 205 to match the tranny, but that just adds to the expense.
    BIGJ
  10. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    700r4 = 27 splines
    TH350 = 27 splines
    700r4's never came with NP205's
    TH350's SOME came with NP205's
    You will need a NP205 from a TH350 (with adaptor and crossmember) for two reasons. A.) The 27 splines match B.) You need a short shaft installed in the 700r4 PLUS the TH350 to NP205 adaptor in order for the 700r4 to bolt up to the NP205. Not only does the 700r4 and TH350 share the same spline count, but they also share the same bolt pattern. Hope this helps.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
  11. sapper
    Jul 11, 2001
    3,052
    NoVa
    Thanks Leadfoot. Off to the yard i go.
  12. BIGJ
    896
    Central Arkansas
    Look for 72 or older chevy pickups &amp; blazers w/auto trannys.
    BIGJ
  13. Leadfoot
    Nov 28, 2000
    3,112
    Also in 1980 everthing came equipped with an NP205, so if it was TH350 equipped, you will find the transfer case, adaptor, drive sleeve, and crossmember. Just make sure it's the original drivetrain though.
