205 to 203 conversion
Discussion in 'The Garage' started by conoverbandit, Jan 19, 2003.
  1. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    I got a 77 model 203 t-case behind a TH350. I have a fella that has a 73 model TH350 but it has the 205 behind it.My question is this, will the 73 model TH350 interchange with my 77 TH350/203? Is the rear shaft the same? Or in other words, Can I take the 205 off and put my 203 and adapter on the 73 model TH350. or am I going to have to change the transmission shaft? Thanks, Conoverbandit /forums/images/graemlins/confused.gif
  2. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I don't know about the splines, but whatever you do ditch the 203 and use the 205. Use the '73 th350, rebuild it if you have to, but ditch the 203. If you're going to have the weight of an iron case better make it a 205.
  3. conoverbandit
    Jan 23, 2002
    452
    Conover N.C
    What's wrong with the 203? I like the full time thing my self,I know it pushes more fuel,BUT, I still like it. /forums/images/graemlins/grin.gif
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I think there is nothing wrong with the 203. My burb came with one and full time to boot. I plan on leaving it that way also....Just my $.02 /forums/images/graemlins/grin.gif
  5. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Both tcases have the same input spline count. I know a lot of people who use and abuse 203's and never have problems....
  6. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    The TH350 output shaft is a 27 spline male. The NP203 has a 27 spline female input and a approx. 1" thick adapter. I will bolt directly to the back of the TH350, but you will need the original 203 adapter plate. The NP205, if it is original to the TH350 will have a 27 spline male input, and requires its origina adapter and the coupler sleeve to connect the output of the TH350 and the input of the 205. As far as which case to run, that is up to you. I personally prefer the 205 because it is all gear drive, no chains to stretch or differential to fail.
  7. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Yes, I realize LOTS of people run 203's with no problems. My point was, and I should have been clearer, spinning the front all the time wears parts faster and uses more fuel. 205's just easier on the driveline, that's all. But as you say, If you can live with it, more power to ya.
  8. conoverbandit
    Jan 23, 2002
    452
    Conover N.C
    Thank You All for your input and answers.Maybe one of these days I'll come around to the 205, but for now I'll just add another fuel tank and stick with the 203(lol). Once again Thanks to all who applied
  9. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I would hang onto the 205 if you can. You may want to swap it in later on. I liked my 203, but when the chain broke I just decided to go ahead and swap in a 205.
  10. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I would try and keep that 205, if you can. If you don't want it, I'm sure you could sell it here!!
  11. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Why not use the best of both.Do doubler trick with 203 and 205 /forums/images/graemlins/thumb.gif
