205 to 208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79tx4x4, Dec 24, 2000.
  1. 79tx4x4
    79tx4x4 Registered Member
    Dec 9, 2000
    17
    houston
    I heard that 205 transfer case is better build than 208, isn't it true? Is it a easy swap? anything else has to be changed?
    Happy Holiday!
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    are you having problems with your 208? If it was me, I'd just keep it in there until something happens to it, if it ever does. The 208 has a better low range than a 205. The 205 is stronger than a 208, but the 208 is still probably the strongest part of your drivetrain IMHO.
    90K5
  3. 79tx4x4
    Dec 9, 2000
    17
    houston
    Will a 4" lift mess up my transfer case? I have a 4" lift on my 84', what else do I have to replace except the springs on front and spacer at the back? I am looking for a good 208.
