205 to a 700r4
Discussion in 'The Garage' started by 91k5NC, Oct 31, 2003.
  1. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    im trying to put a 205 to a 700r4, what do i use to hook these together. 205 came from th400. thanks
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    First you either need a spacer and also the TH350/205 adapter, or replace the output shaft of the tranny with an Advanced Adapters shaft then use the TH350/205 adapter. I heard that the 205 behind the 700R4 without using the spacer will give you clearance problems with the front driveshaft hitting the tranny pan. You also would need to convert the 205 input to a 27 spline input. I am not sure if you can go backwards though from the 400 version to the 350 version, maybe someone else will chime in on that.
  3. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    You can find all you need here .
  4. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    [darn] AA. Their shaft costs $ (or time, same thing) to install cause u have to tear down the whole tranny... it costs 3x as much as the spacer... and when you're done you have tranny pan clearance issues. yay!! I use the spacer... havent had a single problem... I run a deep AL pan... spent less $.. and couldnt be happier.
    j
  5. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Hello EVERYBODY
    WELL 4X4 HIGH CALLED IT THE MOST IMPORT PART OF HIS INFO
    sorry dude 700 r4 =27 spline
    turbo 400- 205 = 32 spline
    cant do it
    any ways i got the solution 4 ya
    trade me 205 t cases ill get the 32 spline i want youll get the 27 spline u need every body wins
    here is my email adress directly
    doctor4x4@hotmail.com
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Advance Adapters sells a new output shaft for a 700R4 that makes it a 32-spline output and has the correct adapter to bolt up to a 205. However, it isn't cheap. It was around $500 just for the parts the last time I looked. /forums/images/graemlins/eek.gif
  7. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    good call Harry
    I learn something new everyday /forums/images/graemlins/thumb.gif
    glad to read this rather then:
    oh ya can have a custom spacer made or just weld up the hole and have it rebored out /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
