205 twinstick ?
Discussion in 'The Garage' started by cegusman, Feb 8, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I am try to get setup twinstick, I can not get it to go into front low. I can get it to do ,rear high, rear low, front high, 4wd high, and 4wd low. Do I need to grind more of the the rail?
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    There was writeup in Petersons last year{?issue?}.It had pretty good oics of how to do the rail.Have to dig through them to find it.Let you know in little while. /forums/images/graemlins/thumb.gif
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I have it, I ground just like they said, just don't know if I did it enough.
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    do a search for mud studs post and check his pics and stuff. it might worka s a refernec.
    nathan
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Are you making sure the rear is in N before trying fornt low? If so, grind some more. I used the distance between the rail poppet indentions as a measurement on how far to grind past the original interlock location. HTH
  6. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    Just did a twin stick today. I ground the new areas approx. 3/8" to 7/16" back from the originals. I duplicated the abrupt end of the one and the slope of the other. No problems work the first time. Hope this helps.
  7. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Thanks everyone, got it to work.
  8. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I am starting to gather all the parts to do a doubler and I am also thinking about the twin stick. What is involved in making it a twin stick? Is there a write-up anywhere on it? TIA
  9. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I just did this mod over the weekend. Before you can shift to front low range only, you need to shift your rear into neutral, this will allow the range range front output rail pull forward the rest of the way. It will also work when you have your rear shift rail (the one you modified) shifted into low range, then you can pull the front into low.
  10. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    hey I just did this over the last couple days and they both seem to shift great except..............
    I was playing and looking at the rear output. when I put the rear into Neutral it still gets power from the input. I"ll get a pic later today and post it to show what I"m talking about. Isn't the rear supposed to go neutral? as in no power and engage the front.
  11. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Just did mine, already got the pics to write an article. I wasn't really happy with the others I found. Pics and explanations lacked quite a bit IMO. You'll have to wait till the Memorial Day mad rush is over though.
  12. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Try holding the rear yoke still while you turn the input. You may just be getting a viscous coupling of sorts.
  13. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    Ivan has a good write up
    Here's a link to Ivan's website on his twin stick.
    Ivan's twin stick
  14. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    doesn't help really...........
    it all works good it's just that the rear dosen't ever truely engage a neutral standing it always turns somewhat. errrrrrrrr :mad:
