205 with 5,13 or 203,205 doubler with 4,56
Discussion in 'The Garage' started by Ronnie4wd, Aug 28, 2005.
  1. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    Now I have broke my 208 for the forth time so now I have to do something drastic.
    Should I change the gears to 5,13 and get a 205 or
    should I go the doubler 203 205 way
    This truck will be used daily driven and tough offroad.
    More specs in sig
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I'd go 4.56's and the doubler
    What do you keep breaking in your 208 ?
  3. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    The house was cracked bad 3 times and this time I don´t know but I think it´s the chain who is too loose so it sounds strange :crazy: in 4wd
  4. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Doubler and 4.56's (I assume that is the ratio you have now)
  5. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    Sorry added that in the sig now
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    im running a 465, doubler and 4.10's with 42's... well, i have it all anyway. most of the stuff ill be doing will be rocks so with single low i should be able to put around just fine and use double low for most of the larger stuff without a problem. maybe one day i will re-gear, but ill go to a 4.56 then.
    in your case i would go doubler and 4.56's as it will give you the ability to drive on the highway with a bit better RPM...
    grant
