205 Xfer case ??
Discussion in 'The Garage' started by 1970Jimmy, Feb 14, 2003.
  1. 1970Jimmy
    1970Jimmy Registered Member
    Apr 27, 2002
    75
    Cookeville, TN
    Do all 205's come with a 1 ton yoke for the rear drive shaft?? If not, which ones did??
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    No they dont. Some are 1/2 ton. You can either run a conversion u-joint (about 30 bucks) or I know on a 203 you can unbolt that yoke and swap them. I just did that last weekend.
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    The 205 came in 1/2, 3/4 and 1 ton applications...chances are you are NOT going to find a 1350 yoke in a 1/2 ton application (most of the 1/2 had 1310's) Look at the 3/4 and 1 ton cases for the 1350 stuff.../forums/images/graemlins/thumb.gif If you find just a 1350 yoke, you can swap it easily!
    Chris
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    You can also swap on a flange instead of a yoke.
