205 yoke 1/2 to 1ton?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by EricM, Jul 30, 2001.
  1. EricM
    EricM Registered Member
    Apr 14, 2001
    61
    Savage, MN
    What is involved in changing the rear output yoke on a 205 case from 1/2 ton to 1 ton. I would think it would be a just swapping yokes but are the bearings and seals different sizes? It is a 205 case from a 72 jimmy with a sm465. I need a new drive shaft so I was thinking about changing the yoke to match the rear 14 bolt. Thanks
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I did the same thing. You need to get a thin-walled socket because an impact socket wont fit in the yoke. It's a direct swap, try not to get too much 90 wt all over yourself when you pull the old yoke off like I did.</font color=blue>
  3. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    How can you tell what u-joints a yoke will accept?
    1970 GMC Jimmy 502HO/SM465/NP205 doesn't run just yet!
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>By the size of where the caps seat and how far apart they are.</font color=blue>
