205t-case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5blazerus, Nov 5, 2001.
  1. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    IS any one out there running a divorced 205 T-case. If so what angle did you mount it at and what problems do I expect to run in to.
    colin
    Save the whales Harpoon a fat chick.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    If I understand the divorced t-case idea, I would say the short wheelbase of a K5 would cause major Drive shaft(rear) problems with the angles and the length. It would cause the t-case to sit way back needing a very short driveshaft causing a severe angle.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  3. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    on the other hand you could mount the case lower than the trans and lessen the angels of both the front and the rear shafts......
    Mike
    The jeep eater ......jeep it's what's for dinner[​IMG]
  4. he's running it with an sm435 out of a 69 gmc. the total combo shouldn't be much longer than his old th350/205 combo. depends on how short of an intermediat shaft he can run.
    <font color=blue> Experience enables you to recognize a mistake when you make it again.
    </font color=blue>
  5. k5blazerus
    Apr 22, 2001
    654
    Bend, OR
    All I know is it is going to work just fine and drivelines will not have any extream angles on them eaither. The whole combo will be just about 1 inch shorter then the 350/205 combo. Dosen't white Knight run a divorced unit may be I should ask him.
