208-->205 slip yoke?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dyeager535, Feb 13, 2002.
  1. dyeager535
    26,975
    Friend has a 1980 slip yoke 205 that he is thinking of swapping in place of his 1984 208. Wondering if the output shaft on his 700 has the same spline count/length (same adapter) as the 350 the 205 is mated to now, and will mate right up like he thinks it will.
    Guess he has ideas of converting it to a non slip yoke, although I think he's half assing it...he SHOULD be running a TH350 or 400 and a non slip yoke 205, instead of a 700 with the 208 or slip yoke 205, but he doesn't have a bunch of money.
    Imagine that, he paid $4000 for a truck he's destroyed, and is now taking all the "good" parts off of, to make it more a wheeler. Not quite sure why the beat, aready lifted, '76 he has wouldn't have served better duty as a wheeler. I digress though, I just think $4000 would have bought one HELL of a nice drivetrain.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    your friend will need the adapter from the 350/205 and also will need to buy the output shaft from advance adapters to have installed in his 700. I have heard that there will be front driveline issues as well because the flange is very close to the transmission. also i think the drivelines will need to be reworked as well.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    which pattern for 205? round or figure 8?
    formerly 77chev
    still a jerk though
  4. dyeager535
    26,975
    I'll find out and report back.
    Dorian
