208 - bearings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblue, Feb 20, 2002.
  1. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    I have the 208 all apart and clean now. I am having problems getting the bearings out....What is the best way to do this?
    Thanks...
    Surfing is Life...
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Tap them out with a brass bar, Don't hit to hard. The brass will bend insted of the aluminum.
    Houston, TX
    <a target="_blank" href=http://community.webshots.com/user/cegusman>http://community.webshots.com/user/cegusman</a>
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    if the berarings are not messed up dont worry about replacing them , it donest matter if u mess them up removing them bcuz u are gonna replace der uh yeah ive rebuilt them before its a loong day today .....FFFFF
    <a target="_blank" href=http://www.imagestation.com/album/pictures.html?id=4292257869&show_all=1&start=1>pics page</a>
    always gets me home K10 STEPSIDE
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Ball-pin hammer? I think thats what its called. I remember those bearings they were a pain! You'll see try the ball-pin hammer before you screw the bearings up. I screwed them up so I used a Dremel tool and carefully cut the races out! Be careful though one scratch and you scred the matting surface or bearing cup.
    Good Luck
    Definately a pavement pounder...with the caveman clutch
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  5. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    for everyones info its a ball pein hammer :)
  6. bigblue
    Dec 6, 2000
    658
    southern california
    They are a little worn...I can't tell if they are really bad or not...I am pretty sure that the main big bearing needs to be replaced...
    Surfing is Life...
  7. bigblue
    Dec 6, 2000
    658
    southern california
    I got them off...it just took a little elbow grease....
    later
    Surfing is Life...
