208 case ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RATAH, Sep 30, 2002.
  1. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    Hello
    is the 208 Tcase full or part time 4X4 ?
    and whats the right way to engage the 4X4 ?
    can i leave the hubs locked and run in 2 hi or do i need to
    unlock and lock when i use 4x4?
    Thanks for all info
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The 208 is a part time, and when you want to run in 4wd you should lock the hubs and then when you want to engage you shift into 4wd, if you run with th hubs unlocked and engage 4wd you shouldn't have a problem but I have had some wear on my axles doing that.
    IceMan
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    - Part Time
    - pull lever back and lock hubs (if manual). if low than put i neutral before pulling lever back.
    - yes, but you shouldn't, that will cause there to be drag in the front drive line.
  4. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    Thanks all
