208 Clocking
Discussion in 'The Garage' started by 79Stomper, Sep 11, 2006.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I just want to know how much you have clocked your 208 to get it level underneath. I am in the process of doing mine and want a flat belly. Should I go with the full 2"? Or maybe step it down a little with the 1 1/2" or 1".
    Overall goal is flat bottom so I can build a skid plate for them.
    TIA:thumb:
    James
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I'm gonna do that when/if I ever get an answer about lubrication, when it's a DD. :D
  3. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I think it should be fine, as the 208 have slingers on the main shaft, as I recall. I could be wrond it has been a LONG ime since I cracked a case open.
    Oh and found the post I was looking for so thanks for stopping in and checking this one out.
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    208's have an oil slinger, not a pump, so as long as the slinger can pick up the oil, there won't be any problems. I would say as long as the level of the oil is near the rear output, it will be fine.
    I'd clock that sucker flat. No worries about the t-case hitting the body because I think you are running a body lift right?
  5. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Yeah when some funding frees up I will be running a body lift.
  6. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    I've got two of them dissassembled at the house. If you need pics of the slinger, let me know.
  7. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Slinger...............somebody say "Slinger"?
  8. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    I have mine clocked flat and dd it that way for about a year no issues. Well I overfilled it so much at first that when the fluid expanded it came out the extened breather tube. A little leaked out and it fixed itsealf. I do not have a body lift and have x members made of 4x2 and the skid is flat but from the bottlom of the x member. So a 2" body lift would work I would think. Just watch your d-line angle in the front it can get nasty fast. I have been thru 2 so far and now I am running a tom woods with super joints at both ends and it still needed a little more clearencing to accomidate the flex of the 52"s up front. So good so far.
  9. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Photos please!!! :D
  10. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Also any exhaust clearanc eissues? I kind f figured about over filling it but knowing me I will do the same thing......
