208 CV Rubbing
Discussion in 'The Garage' started by Brodie, Aug 5, 2006.
  1. Brodie
    Brodie 1/2 ton status
    Mar 20, 2006
    255
    Puyallup, WA
    I just put a six in lift on my 81 K-10 and finally got to run it in 4wd, and noticed a problem. In 4wd, when I get on the throttle there is a rubbing sound coming from the X-fer case. When I looked under it I noticed that the upper U-joint was rubbing on the cross member. Only when I romp on the gas. When I was putting around it worked like a champ. Is this a common issue, and if so how can it be fixed? Thanks for any help.
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    same thing happened to me---if you have access to a torch or a gringer w/a cutoff wheel, just cut a little 3"x1.5" hole(where ever the cv is hitting) and you will be fine. i ran this way for years with no problem.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I had to do this with a 4 inch lift .
  4. virgilh
    virgilh 1/2 ton status
    Sep 8, 2004
    343
    Sacramento California
    spacer
    superlift makes a spacer you can use i think its a 4040 part# it spaces the front driveshaft to clear the crossmember and helps with makin it a little longer with the lift. i wouldnt cut anything
  5. Brodie
    Mar 20, 2006
    255
    Puyallup, WA
    Thanks for the ideas. Glad to see I didn't funk anything up. I think I'll look into that spacer.
