208 CV Slip Yoke Leak - MIG or Braze
Discussion in 'The Garage' started by rcamacho, Feb 22, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I tried JB weld and it did not fix the leak - it's definitely still seeping from the yoke plug. So, do I braze or MIG it? I have a decent 220V MIG that I can tune down - .035" flux wire currently.
  2. tacomuncher
    tacomuncher 1/2 ton status
    Jan 3, 2006
    110
    goleta ca
    have u tried to replace the output shaft seal? 10 -15 dollar part...
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    Yep, new seal and output shaft bushing. The slip yoke surface is dry, it's slinging ATF from the yoke plug.
  4. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    call me an idiot but what do you mean by a "yoke plug"?
  5. rcamacho
    Jul 1, 2004
    1,324
    WA
    There is a plug at the end of the machined spline to keep ATF in the tranny. Typically it is crimp fitted and thus leak prone.
  6. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    i popped mine out and put some rtv around it then put it back in
  7. rcamacho
    Jul 1, 2004
    1,324
    WA
    Well I finally gave up on JB weld. The yoke hydro locks on compression and forced fluid past the epoxy. I've welded the margin between the plug and yoke. The welds look like crap and it took a few passes to make it air tight.
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    That plug is supposed to have a small hole in it so that the yoke does not hydro lock. If it is leaking from this plug the yoke splines are wore out and the yoke needs to be replaced.
  9. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Another symtom of warn yoke splines is the slip-yoke "clunk" when you come to a stop and start from a stop. I think GM even had a TSB on this...or maybe it was Jeep:dunno:
    __
  10. rcamacho
    Jul 1, 2004
    1,324
    WA
    Nope, plug is solid and the yoke is new. Splines on the transfer case main shaft are good.
