208 doubler project...updated 3-10-06
Discussion in 'The Garage' started by ryan22re, Dec 11, 2005.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    i pulled apart my 208 to see how easy/difficult it would be to make a doubler like ive heard that the BW ford guys do and mad rooster ( http://www.pirate4x4.com/articles/productreviews/mad_rooster ) does. it doesnt seem that hard, except for the oiling of it. it seems that the planetaries get oil from the slinger here:
    im thinking that i will flip the 208 upside down to help make room on the pass side for a front driveshaft. which, i was planning on having the mainshaft machined for oiling to the front bearings, but, with it upside down the slinger wont direct any oil up front.
    how critical is the slinger/oiling to the front bearings? i was thinking about filling the half 208 up to about the height of the mainshaft, but i dont think that oil will make its way to the front bearings. furthermore, ive seen the guts of a klune-v and see no where in the drawings about lubrication to the input or output bearings. am i just looking for a reason not to build it?
    heres where i plan on cutting it :
    outside view:
    or just cut it straight across.
    what do you guys think? i plan on bolting a 205 to the back of it. i hope to be able to bolt a 400 to 205 t case adapter to the back side to provide another mount for supporting the weight of that heavy 205.
    ryan
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
  3. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    thats where i got the idea. it doesnt seem that he did anything for the oiling of the thing either. wonder how it holds up on the street.
    ryan
  4. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    the 241, which i think is way close to the 231, uses an oil pump. I would use one of those so that you dont have to worry about the oilling issues.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    the oil pump mounts to the back half of the tcase so this setup would remove it.
  6. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    since the 208 uses a slinger, i dont think that it would be that hard to reuse it, just have to have the shaft splined in that section to attach it. but i dont think it will channel oil to the planetaries, but im thinking of overfilling it. (in relation to where the fluid level would be stock).
    ryan
  7. jason m
    jason m 1/2 ton status
    Feb 12, 2005
    173
    holland mass USA
    insteed of using ATF could you use something heaver like 50 wheaght gear oil, mix some lucas in there and i would think those planitaries would be fine. the 231 crawler box's dont use any thing different ( i dont think ), jason.
  8. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    208 doubler!!??? :eek1: :D gotta couple 208s and a 241c :ears:
    hmm the 208's and the241c I got have all have 32-spline input and output shafts. didn't even dawn on me before - thanks man! :thinking: 5.52:1 in low range. :eek1:
  9. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    yeah but i think that the 208 or 241 wouldnt be able to handle the input torque from being multiplied by 2.61 or 2.72. thats why i want to use a 205.
    ryan
  10. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    ryan
    I think your idea holds alot of potential...! Anytime you can make something good outta the parts everyone is throwing away - it's a good thing..:thumb:..!
    I've done my share of lookin' at the guts of the 208. I'm using them in an "unconventional" way also... See thread
    The 208 does have a pump to lube the planet gears and stuff in the front. It's plastic and mounted on the rear output shaft. Looks kinda like a speedo gear and has a black plastic "shroud" that comes off in your hand when you remove the tailshaft housing. So.. your setup will be eliminating this pump.... :thinking: I don't think that will be a problem provided that you get a "fill level" up to the bottom edge of the mainshaft. I would also stick w/ ATF as a lubricant.
    In my setup, I've clocked the 208's flat and I drive the 1st one bassackwards....:crazy: So the pump is still in there, but if anything it is working in reverse. I just filled the cases approximately 1/2 way up - and have yet to have any problems. Now... I will say that this is an "off road only" rig, so I have yet to clock alot of hi-way miles. But I have driven 40-45 mph down several dirt roads....
    Good luck.... Hope it works!
    Marv
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    Hmm this is interesting.. NWF was supposedly looking into something similar to this. I think there was talk about it in one of their posts on Pirate or here. DOnt know if they got anywhere with it though..
    I'd like to put a 208 or 241 planetary set in front of my 241. :thumb:
  12. hack500
    Sep 16, 2005
    523
    Templeton, Ma
    if you're going to use a 205(with a 32-spline input)... could just remove the tailshaft housing off the 208 and make an adapter to bolt the 205 to the back of that. should've asked before but are the 32-spline input and output shafts the same major/minor diameter? I think they are but I haven't measured 'em yet to find out.
    should also connect the 2 adapters together so that the back of the 208 isn't holding the 205 up and you'd still be able to use 1 crossmember, if you so desire.
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    That combo would be really long. Plus you would be leaving the weak chain in the equation. Whereas if you just used the front planetaries, you eliminate the weak chain.
  14. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I have .....
    They are the same..
    Marv
  15. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Agreed..... Using the front half of the 208 would be a much more attractive package.
    The chain would be in there.... but you wouldn't be driving thu it.... It only turns the front output of the 208, which you wouldn't be using.
    Marv
  16. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    I can also second this. Had a 241 with a broke output shaft, stuck it in the input for safe keeping. Fit right in.
  17. hack500
    Sep 16, 2005
    523
    Templeton, Ma
    the extra length really isn't that much to me. just going from memory it seems it'd only be an additional 8-12 inches.
    sorry didn't intentionally mean to hijack.
  18. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    with all of the 208s around, i figured it be a good idea.
    i wasnt plan on eliminating the slinger. i was planning on a custom shaft anyway, so why not have it splined and drilled for the slinger/bearing oiling. but i do plan on probably flipping it over to make room for the driveshaft on the pass side. which, wouldnt channel any oil to the planetaries, but would hopefully still oil the bearings. or like you said, fill it up about level with the mainshaft. if i bust it, ill just buy another 208 and start over.
    thanks marv. :bow: i was planning on getting a couple of 208's are junk, just buy a doubler. ill try to keep up with any progress i make, but i move kinda slow, so bear with me.
    ryan
  19. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    oh yeah, does anybody have a measurement of the distance from the center of the input shaft to the center of the front output shaft on a 205?
    that would help me decide where to cut it and whether or not my 208 will need to be flipped over.
    ryan
  20. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    10 inches.....
    ....and I'm not bragging.:D :haha:
    BTW, the 208 measures the same.
    Marv
