208 FIXED YOKE KIT OR CONVERSION
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by superbee, Mar 12, 2001.
  1. superbee
    superbee Registered Member
    Mar 4, 2001
    6
    NH
    I GOT A 88 K5 350,700R4,208 W/SLIP YOKE AND I WANT TO ELIMINATE THE SLIP YOKE AND SET UP W/A FIXED YOKE INSTEAD. THE REASON I AM DOING THIS IS MY 78 K5 HAS BEEN WELL HASHED ON AND I WANT TO SWAP OUT MY AXLES AND SUSPENSION AND CUSTOM MADE DOUBLE CARDONED DRIVESHAFTS FROM THE 78 AND UNDER MY 88.DOES ANYONE KNOW WHAT I CAN DO, AND IF PIECES FROM A FORD 208 W/FIXED YOKE CAN BE SWAPPED TO A CHEVY 208. I NEED TO TAKE CARE OF THIS BEFORE I CAN SWAP THE OTHER STUFF IN. ANYBODY WITH ANY IDEAS PLEASE E-MAIL ME....MARKRODIER@AOL.COM
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    You could swap in a NV241, they can be modified with a slip yoke eliminator kit, but not the 208. The 241 should bolt right up, and see jb conversions for the slip yoke eliminator.
  3. superbee
    Mar 4, 2001
    6
    NH
    YEA BUT IS THE OUTPUT SHAFT SPLINE COUNT AND SIZE OF THE 700R4 THE SAME AS THE 241 INPUT SHAFT. I WORK A DODGE DEALOR AND I DONT THINK THEY ARE THE SAME. I DONT KNOW MUCH ABOUT THE 700R4 THOUGH.
  4. superbee
    Mar 4, 2001
    6
    NH
    HERE IS ANOTHER QUESTION.. WILL MY 203 OUT OF MY 78 FIT BEHIND THE 700R4???
  5. iceman
    iceman 1/2 ton status
    Oct 26, 2000
    208
    Littleton, CO. 80127
    If your 203 was behind a 350 turbo, you need to swap out the output shaft of your 700r4 with one that ORD sells. That's the first step to the doubler process. Iceman
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    In 88 you could have either a 208 or a 241 from the factory. My guess is that the switch occoured sometime in the middle of production. The 241 should be a direct bolt in. You can also change the output shaft on the TH700 and get a 205 although I am not sure what else needs to be done.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
