208 fixed yoke kit?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by superbee, Mar 4, 2001.
  1. superbee
    superbee Registered Member
    Mar 4, 2001
    6
    NH
    does any one know of a fixed yoke kit or slip yoke eliminator kit the same as design as a 231 tcase
  2. iceman
    iceman 1/2 ton status
    Oct 26, 2000
    208
    Littleton, CO. 80127
    I heard this was gospel, take the back half and output shaft of a, sorry to say this "FORD" 208 t-case with a fixed yoke flip it over and install it on yours. I haven't done this but was planning on it, so I asked a local tranny rebuilder if they were the same, and he said yes.. Let me know Iceman
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I also heard you can do the same thing with a Dodge t-case too.
  4. iceman
    Oct 26, 2000
    208
    Just finished the fixed yoke conversion. Everythings inplace and seems to work fine. Iceman
  5. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i need to do this too...will any ford 208 work?
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, Im assuming this is what Jesse "onetoncv" aka "drivelineman" does. He sells these kits. You can call him at 530-872-5725 for $325.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  7. iceman
    Oct 26, 2000
    208
    I picked up a 208 out of an 80 "ish" full size Bronco. I had to make a small mod to the shift fork and lever but other than that it was bolt together. Total cost about $125 this was my first 208 teardown. Iceman
  8. what was the small mod? this sounds cool. i have a 208 sitting in my garage waiting for my 203 to go.
    78, 350/350/203, 3/4 ton, 4" lift, 35" BFGs[​IMG]
    <A target="_blank" HREF=http://bluebeast.coloradok5.com/>http://bluebeast.coloradok5.com/</A>
  9. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Yes, what "small mods" did you have to make to the case? I want to do this, sort of a stopgap measure until I swap for the doubler setup...
  10. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    oh do i need this!!!!!!that will cure my phobia of the 208 slip tail shaft w/ lift.
    PURE INSANITY
    86 blazer see it at:<A target="_blank" HREF=http://www.zing.com/album/pictures.html?id=4292792569>http://www.zing.com/album/pictures.html?id=4292792569</A>
  11. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    will this also work w/a 241?
  12. kpanza
    Dec 8, 2000
    1,579
    1990K5,
    You can get a kit for your 241 that replaces the slip yoke...check this out:
    <A target="_blank" HREF=http://www.jbconversions.com/pages/np241/index.html>http://www.jbconversions.com/pages/np241/index.html</A>
  13. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    iceman,could you do a tech article on this,id really like details.
    PURE INSANITY
  14. iceman
    Oct 26, 2000
    208
    I never thought of it before but I could try a tech article. But for now the mod is a simple one. You disassemble the two cases and use the output shaft and everything on it, the rear shaft housing, yoke, shift fork and lever. I had to redrill the case for the Ford tail housing bolt pattern then I ground some 3/8x1 bolt heads to fit from the inside out, I put a heavy amount of silicone on the heads to hold them in place. Under trial and error I found that the shift fork (used from the ford case) needed to be shortened slightly and the stub on the lever had to increased in diameter. I shortened the shaft with a hack saw and file (rasp) about 3/16 in. and increased the size of the shifting pin on the lever to 3/4 in. dia from 1/2 in. The rest of the reassembly is according to the book. Except plug the Ford vent tube on the tail shaft housing and drill and tap your top fill plug for a vent. It really wasn't a bad project just don't take any thing off the Ford shaft you'll use the shaft as it is and you'll need the Ford speedo plug and gear. I hope this helps if you need more just e-mail me. Iceman
  15. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I wonder if you used Dodge parts, if it would bolt together with no mods, since they are both RH drop???
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  16. bigerik
    bigerik 1/2 ton status
    Feb 24, 2001
    184
    Sonoma County, CA
    I had just sent in my $695 to Boyce Equipment (800-748-4269) for a reman NP208 when I read this post. I called Mark at Boyce and he says he has thought about marketing such an option and may use my order as a guinea pig. He says he's gonna make some calls and charge me according to his cost. I'm gonna refer him to CK5 and this post. Iceman, I wish I was mechanically inclined enough to do that conversion.
    <A target="_blank" HREF=http://www.bigerik.coloradoK5.com>http://www.bigerik.coloradoK5.com</A>
  17. bigerik
    Feb 24, 2001
    184
    Sonoma County, CA
    I saw in Cheap Tips in Four Wheeler magazine that if you have a slip yoke output that needs to be removed in a trail fix, you can drive the vehicle for a ways if you put the right plastic sports drink bottle (20 oz.?) at the rear of the t-case and wrap it with duct tape.
  18. iceman
    Oct 26, 2000
    208
    I choose the Ford box because it was plentiful and cheap. Dodge t-cases seem to be more expensive for some reason. I'll try to keep you informed of its performance. Iceman
  19. kpanza
    Dec 8, 2000
    1,579
    Yes BigErik, that is a trick that I can vouch for!! I once had to drive home all the way from Palm Springs (about 100 miles) after breaking the rear driveshaft off in the dunes with this bottle/duct tape trick! And to top it all off, I had to tow my brother's sand rail trailer the whole way - all the way home on the highway in 4Hi with a leaky t-case and duct tape and plastic keeping my t-case alive! It works!!!! I now keep a stash of paint can plastic tops and a bottle in the center console just in case it happens again!
  20. BlazerMatt
    BlazerMatt Newbie
    May 18, 2001
    I started to do the same conversion, but I found that the Ford 208 engages the chain by sliding the ring forward, while the Chevy 208 engages it by sliding BACK... So, with the ford shaft, [censored] fork,etc in the case, it's shifting backwards... I think I can get it to work, but its a real pain to shift, because the angled teeth that help engage the gears are facing the wrong way...
