208 for 241 swap - direct bolt in?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kpanza, Mar 13, 2002.
  1. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Looking for help here,
    Am thinking about swapping out my 208 case for a 241 case. The 241 case is out of an 89 truck, so it has the mechanical speedo gear, which will match my 87. Is this a true direct bolt in swap? I mean, no driveshaft length changes, no adapter differences, shift linkage differences, etc?? Basically unbolt the 208, bolt in the 241 and plug the speedo cable in and go?
    Thanks for any help - and if it isn't a direct swap, what needs to be done to accomplish it?
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    why switch ?
  3. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    241's are supposed to be a little stronger than 208's. Also you can get commercially available slip yoke eliminator kits. Of t-cases that are stronger than 208's (and common) the 241's have a 2.72 (I think) low range, which is a quite a bit more than the 2:1 of the 203 or 205, but it is still aluminum (not necessarily a bad thing...lightweight).
  4. grtwhite
    grtwhite 1/2 ton status
    Aug 3, 2000
    366
    Macungie, PA
