208 front CV grinding
Discussion in 'The Garage' started by rcamacho, Mar 6, 2007.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    http://www.4x4wire.com/toyota/tech/cvmod/
    I had to replace the u-joints on my front driveshaft last weekend and noticed that the CV is close to running out of clearance at the CV/transfer case side. I estimate it only has a few inches of droop available before the CV bottoms out on the stops.
    Q: has anyone on the board had success with clearancing the stock CV joints? Tips/pics?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    That link you have up there is a very complicated way to do it.
    I just grind off about 1/8" off the driveline stops. The drive line stops are there to keep your drive line from hitting the ground if you break a U joint.
    But if you have lifted your truck they need to be ground off.
    Go to this link and read the bottom of page 2 that says" Front U joint modification". :http://www.roughcountry.com/install/145S.pdf
    Its a PDF file. Tells exactly how to do it.
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
  4. rcamacho
    Jul 1, 2004
    1,324
    WA
    Worked like a charm. I used my 4 1/2" grinder to take off the stops. There are some internal stops on the CV that also needed some work with a die grinder. Net-net sigificantly increased operating range.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Some of us have also had to grind some off the crossmember , if your front flexes pretty good .
