208 front output help *urgent!*
Discussion in 'The Garage' started by jk3078, Aug 11, 2006.
  1. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Whats the torque spec for the front out put on a 208? I was getting my truggy ready to go to the races, leaving in two hours, and noticed about 1/2'' of slop in and out so I'm hopeing I can tighten the nut down and solve this problem. Thanks
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I want to say that that sort of thing is usually around 150 ft/lbs or so, I'm not sure. I'd just get it as tight as you can, maybe throw some loctite on it if you're really worried. I don't usually worry about torque values too much, I believe I usually have an idea of an appropriate amount of torque to give things depending on the application, but it kinda comes with experience. Motors, on the other hand, are another story.
  3. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Thanks, I tried to tighten it down and it would not budge so I guess I looking for a new t-case.
  4. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    Just think of it as extra slip. :)
