208 front output nut torque specs
Discussion in 'The Garage' started by big83chevy4x4, Jun 1, 2004.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i need the torque specs for nut on the front output flange on the 208, i replaced the seal a few months ago and it has come loose twice now /forums/images/graemlins/angryfire.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not sure on the 208 but the 205 is 250-300 or so ft lbs. That nut doesn't preload a bearing, it only holds the yoke on.
    Since it's likely a prevailing torque style nut you might need a new nut.
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    well im not buying a new nut, im having another 208 being rebuilt (free /forums/images/graemlins/woot.gif) and just need it to stay on till then.
    what is a prevailing torque style nut? /forums/images/graemlins/thinking.gif
    i know it was a motha to get it off, but i though i got it tight enough the first time. the second time i just tightened it up so it wasn't loose and it stayed like that for 2 weeks. /forums/images/graemlins/thinking.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A prevailing style lock nut is commonly used in high temperature and critical applications like a pinion nut, or as you found, a front output nut.
    It can't be repeatedly reused (that's why it was a bitch to get off). It is designed to be installed and stay where you put it so it doesn't come loose.
