208 help
Discussion in 'The Garage' started by ftcjimmy, Dec 30, 2005.
  1. ftcjimmy
    ftcjimmy Registered Member
    Mar 9, 2005
    61
    ct
    I just swapped out a bad np208 for what i thought to be a good one. I start it up, go to put it in drive. Nothing:confused: . Reverse...Nothing:confused: . I go to put it back into park and i get a grinding noise:eek1: . I disconected the transfercase shifter from the case and make sure its in 2 high because the shifter wasnt putting it all the way in.....the linkage needed adjustment. Still nothing. When i put it into reverse and drive the motor idles down a bit just as if i was sitting there holding the brakes when putting it into drive. thats normal. Anybody have any ideas as to what my problem is before i have to drop it again? thanks -DJ
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Put it in 4 low and see if it grabs , maybe bad shift fork on the range selector .
  3. ftcjimmy
    Mar 9, 2005
    61
    ct
    nope. shifted through all the ranges. nothing.:(
  4. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    were the splines ok on the input sleeve of the t-case? if they are stripped, it will do what you are experiancing
  5. ftcjimmy
    Mar 9, 2005
    61
    ct
    just kinda threw it on....not sure. looks like im droppin it again tonight:crazy:
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Don't be scared to take the case halves apart . Its easy to tear into this , just need an exploded view and pick up the needle bearings to reassemble . There is a post with the guts pic on here , have to dig it up .
    Loved to know what happened to it !
  7. norville
    norville 1/2 ton status
    Dec 27, 2005
    268
    A stones throw from Pargon Mountaintop Pa
    Please let us know what happens. I'm looking at sub with a 208 and a "tranny problem". When I looked at it it was in 4 low. I'm thniking it has a bad fork in the TC . And the PO thought the tranny was shot.
    thank
    bob
  8. ftcjimmy
    Mar 9, 2005
    61
    ct
    WEll my DD just lost its brakes so i probly wont get around to the case till late tommorow morning. ill post up as soon as i figure it out
  9. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Is there any reason not to think it might be the tranny?
  10. fordtruggy
    fordtruggy Registered Member
    Dec 30, 2005
    55
    Red neck ville Rapid city SD
    If the T case is in nutral it will do exactally what you are saying.But I dunno what else it could be doing other than the splines not being wright...?
  11. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    mismatched>???
    Maybe he put a TH400 style 32 spline NP208, on a 700R4 tranny with 27 splines about 1/4" smaller in diameter????..that would make for some slippage..:thinking: :whistle:
  12. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    Bingo!
    Thats exactly what happened when i installed one for a sm465 instead of for my 700r4.
  13. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    that does seem very plausible...
  14. dave_90_blazer
    Jan 1, 2004
    688
    yeah, I thought of that last night when I was drunk
  15. ftcjimmy
    Mar 9, 2005
    61
    ct
    And that was what it is, wrong spline cout. The input on this new case was bigger. But hey on the plus side, ive cut my case swap time down to about an hour and 15 min., with simple hand tools!:laugh: Never know, this may come in handy on the trail someday.:wink1:
  16. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    keep that case??
    I'd keep the "wrong" NP208 in case you want to upgrade to a TH400 or SM465 someday(you'll need the adapter that goes to them too though)..Either that or maybe you could sell it..possibly to ME!..but I do have 1 "spare" already..
    I bought a NP208 and a TH400 adapter at Thompson Speedway's swap meet last year for 30 bucks..I'm hoping its a good one,(feels ok turning it by hand,and it shifts ok)--the one in my 82 K20 doesn't come out of 4wd anymore,so I just unlocked the hubs this summer,and didn't use it too much anyway(mostly I just plow with it and use it in poor weather)..
    Once you do a R & R of a T-case,you find its not that difficult really..other than a few hard to get a wrench on bolts,lifting it up and getting it in is the hardest part of the job..A NP208 is easy compared to the NP205 cast iron case!... about 100 lbs easier!.:crazy: .
  17. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I posted the Xplode of the NP208, from the '85 parts book. Let me eat breakfast, and I'll post again.
    PC problems here, it won't upload.
    Tried again at 15:00 PST with "pictures", maybe not my PC.
  18. WarrenLovell
    WarrenLovell Registered Member
    Jan 1, 2006
    8
    San Diego
    Sounds like what mine was doing...and I drained the fluid and out came white vinyl shifter fork covers!...Now it only does it when I slam on the brakes.
    Warren
