208 in trouble
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjack, Jun 18, 2000.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    My 208 t case is in big trouble. I've had a bad vibration coming from under my truck. I rebuilt my 700r4 and bought a REBUILT t case from the paper. Anyway I've replaced both u joints the rear pinion yoke and now the vibration is worse. I went to shake the driveshaft to check for play and I burnt my hand! The tail shaft on the tcase and the slip joint were too hot to touch. I thought it was the catalytic convertor causing it but the heat shield wasnt as hot as the slip joint and t case. Any ideas? This is driving me nuts. The drive shaft is in balance.
  2. stephan van leir
    stephan van leir 1/2 ton status
    May 4, 2000
    181
    central Colorado
    The NP. 208 runs ATF fluid NOT 80/90w. I`d bet the farm that you are running the wronge oil. The 208 has a chain oiler in it that keeps most all of the internals wet and cool. If you did run 90w. change it. Run the truck for a FEW miles, than change it again. Keep changeing it till you feel safe. Above all do not run the truck till you get this figured out.
