208 Leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by clean84K5, Oct 9, 2005.
  1. clean84K5
    clean84K5 Registered Member
    Apr 7, 2005
    11
    Galveston, Tx
    I've got an 84 k5 with a 208 and a six inch lift and the transfer case has been leaking its fluid out of the tail shaft where the driveshaft enters ever since i lowered the transfer case 1 inch. I have replaced the seal in the tail of the t-case about 3 times now hopnig to fix the problem but no luck. Could the transmission fluid in the case be coming out just because it is tilted back too much? Anyone with a similar problem?
  2. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Are you sure the fluid is coming out around the seal? Check the driveshaft yoke and make sure it is touching the seal all around. Also look at the freeze-out plug looking thing in the end of the yoke. They will leak and look like a tailshaft seal leak. Also, make sure the T-case is not overfilled.
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    There is a bushing in the end of the shaft, which usually gets damaged pretty easially. It allows too much fluid by, then it gets thrown out the seal. Not sure of the part # off hand. I bought two a while back, and keep one as a spare. Was about $7 I think...
  4. randy88k5
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Found the part # for future reference...
    NP208 tailshaft housing bushing - # 03978765
    Paid a little over $5 a piece
