208 not wanna play fair
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NewK5Guy, May 11, 2001.
  1. NewK5Guy
    NewK5Guy 1/2 ton status
    Mar 2, 2001
    556
    Alexandria, VA
    Hit a gravel side road today, reached down and threw it in 4H. Interesting way my np208 feels when shifting into 4H. It's seems a bit reluctant, almost downright tough, then clunks hard when I put it in drive and roll away. Is this right? I'm assuming it's some sort of fork/gear engagement. It take considerable effort to put the lever in 4H.
  2. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    How does it feel when you shift into 4H when you have it in gear and moving slowly? A lot of times I've found that when shifting into 4H the first time after engaging the hubs, it goes in a little harder if you are in Park. It's always easier if you are in Drive and moving, everything is already rotating and ready to be "locked together".
    Build it Bulletproof and take it fishing!
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    2nd that--
    sounds normal to me, some would say that is the feal of a "solid" engagement. NPF
    Twizitid
