208 Or 241 T-Case??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLUESMAN, Nov 12, 2001.
  1. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I want to replace my current trans with a TH700 and am wondering if I should look for a 208 or a 241 case with it.The 88's and up have stronger trans,Right?What's the diff. in the 208 and the 241's(besides the 241 having a slightly lower lo range).Any problems with swapping to the 700/208(241) that I should know about.Currently have the Th350/203 combo in it.I'll be running 35" tires.Thanks.
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I'd go for the 241, there seem to be more aftermarket parts available for it. Plus I wasn't very happy with the 208 that i used to have in my '85, especially the shift fork pads.
    73K-5: TBI350/TH-400/NP-203/14FF/D44
    Topless, doorless and no tailgate!
    Fresno, CA
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Try to find a 241. Better low range, better oiling system, possible a little stronger. I like mine a lot. It does sometimes need some force to shift, but thats my only complaint.
    90K5
  4. BLUESMAN
    Oct 3, 2001
    951
    Is the 241 a "shift on the fly"?I mean can I shift it manually without a vacuum source or otherwise?I know the Q sounds stupid.I want a T case that I just can bolt up with no headaches.I'll be looking for one already attached to the trans to save some problems.Should I grab the driveshafts too?Or will existing shafts work?
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The 241 is supposedly shift on the fly, but every now and then, when I do it sometimes it grinds. Then I stop, put it in N, and shift. But your supposed to be able to shift into 4Hi going 55
    90K5
  6. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    the 241 is a good case, go with it. and there's more after market stuff for it. it's strong enough for my suburban with 36"s. i've never shifted while moving does it actually work?
    people that get good mileage aren't having any fun!
    scott,
    1989 GMC suburban 3/4t 4" lift finally rollin on 36" swampers, tbi350, th350, np241
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's supposed to. So is the NP 208. As long as your hubs are locked in.
    I don't do it. I don't want to know if it's possible.
    Tim
  8. BLUESMAN
    Oct 3, 2001
    951
    I was more concerned about not having any weird ass vacuum lines...is that only for the later model frt. hubs?The T case is just a manual shifted unit,right?
  9. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    241 is a manual case, no vacuum lines. Only consideration is that '90 and later ones will probably have an electronic speedo output. 241 is a much better case than a 208.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  10. BLUESMAN
    Oct 3, 2001
    951
    Thanks!....so I'm looking for a 88 or 89 model.Right?And grab the driveshafts if they are on a K/5?What about the x member...or will the stock member work?
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'd grab the driveshafts regardless. The front shaft should be pretty much the same for all the solid front axle trucks. The rear shaft from a pickup may be too long, but getting it shortened is much cheaper that buying a whole new shaft.
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I like my 241/700r4. It is holding up well. I shift mine on the fly all the time. I live in snow country and shift in and out of 4 wheel drive under 55 mph with no problems or grinding as road conditions vary a lot around here. I just let off the gas and shift.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
  13. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    The 241 will bolt up just like any other case really. My 241 is dog simple. Think of it as a slightly improved 208. The 89 would prb. be the easier swap than the later models. Also, make sure and check the tag on the back, knoowing the General, they might have stuck some 208's in just to get em off the shelf.
    Kyle
    89K5
  14. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    I read that in the old brochure for Blazers that the 208 was shift on the fly under what I believe to be 15mph.
    I personally put it in N then 4 just to be safe...
    thats my ¢2
    KEN
    DANGIT it's not a bronco!
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
  15. BLUESMAN
    Oct 3, 2001
    951
    Anyone have any pics of a 241 so I know what to look for?
