208 problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieBlazer, Jul 21, 2001.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Okay so i replaced the range selector fork in my np208 and sure it stopped hoping out of gear...now it makes a grinding noise after i get going a little bit...its like an off and on grinding noise....definately from the t-case....any idea's? I think the problem is that the shifter is not holding the t-case in gear enough...could be wrong...anyone had similar problems?
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    The range selector fork has nylon bushings that fit on the "dog ears". When the old fork wore out it prbobly cut into the collar it rides in. What your hearing is hopefully not the new bushing and "ears" being ground to nothing again. Did you replace all of your thrust bearings correctly? I'm more curious if you pulled your output shaft and dropped all million and ten needle bearings like I did?!
    "My blazer may be slow, but it goes faster at higher speeds"
    <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. BowtieBlazer
    Jul 15, 2001
    2,462
    yep it was even more fun removing all million bearigns from inside the case...looks liek I get to dig in again and see whats goign on this time...
  4. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    When i put my case back together I greased that shaft and then stuck it in the freezer. It helped keep the bearings in place a little longer. I dont think that grinding you hear is the tcase not engaging. The only time you should hear a grinding noise is going into low or out of nuetral when the planetary gear is moving. Your high gears should mesh pretty well. Try to put the tcase in 4 high and see if it still grinds. Hope it works out without another tear apart.
    Jim
  5. BowtieBlazer
    Jul 15, 2001
    2,462
    In 4-H it doesnt make this noise....so i dont get it why would it only do it in 2H??
  6. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Could be a thrust bearing, I dunno. It's been a really long time since I tore mine apart so I really don't remember all the little things I fixed. But it kind of rules out the dog ears grinding. As far as I know the chain is basically stationary when in 2 hi so that can be ruled out. I'd call some tranny shops and pick their brains a little bit. Good Luck. Lemme know how it works out.
    Jim
