208 question
Discussion in 'The Garage' started by sledheadak, Sep 1, 2005.
  1. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    A friend has a bronco with a 208 in it but his tcase does not have a slip yoke.Could the rear section from a ford 208 be installed on a chevy 208 to eliminate the slip yoke?
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    NOPE the output is on the wrong side . you could swap the whole case and use a ford hp d44 or d60 tho . -Andy
  3. sledheadak
    Apr 29, 2005
    1,283
    anchorage,alaska
    the housing there the rear output bolts to the main case looks like it has the same pattern if so then could just the rear output shaft and tail shaft housing be switched?i have a extra 208 chevy and will find a ford 208 this winter and see if it can be done.was just wondering if anybody on here had tried it.
  4. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    Use parts from a dodge 208 thats what I have seen people do, or just get a 241 and put a SYE on it.
  5. jmd4x4
    jmd4x4 1/2 ton status
    Apr 4, 2005
    137
    Rosenberg TX
    The bolts will line up for the housing but the oil return will not line up when it is bolted together. The ford out put shaft will not work in a chevy housing, it is off by about 1/8 of a inch.
    later
    jmd
