208 question
Discussion in 'The Garage' started by Dogman12, Apr 21, 2007.
  1. Dogman12
    Dogman12 1/2 ton status
    Nov 12, 2006
    111
    Easthamptom Ma. 01027
    My 208 32 spline stopped shifting, so i picked up another 208 but it is a 27 spline. Can i open them up and swap the shafts?
    Jesse
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    yeah. It is easy, can be done in a few hours.
  3. Dogman12
    Nov 12, 2006
    111
    Thanks, anything i should look out for?
  4. readymix
    May 30, 2004
    6,706
    26
    The 2 million needle bearings in the center of case.
    I don;t remember how many there are but you'll see when you pull i apart. Be sure not too loose any of them.
  5. Dogman12
    Nov 12, 2006
    111
    I pulled the broken cases apart today, no needle bearings, i just removed the front part of the case and removed the shaft, i did not have to mess with the chain or anything, found lots of chewed plastic parts but no chewed needle bearings.
