208 rear bushing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aj_tatted, Jan 6, 2004.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    has anyone ever replace the bushing in the rear tailshaft of a 208 T/C. i think mine is blown out and i need to replace it.and i'm not sure how to do this. /forums/images/graemlins/1zhelp.gif
  2. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    yeah, took mine apart this past summer and changed the bushing, seal and the bearings in the tailshaft. Not hard at all. It was first time in a transfer case, and I found it very easy. I took the tailshaft of, pulled the seal out, got the bearings out and used a piece of pipe to know the bushing out.
    I do recommend using GM part # 1052942 (Gasket Maker) when re-installing the tail shaft. It's a non-aerobic sealant (needs no air), and the guy at the GM parts counter recommended it. I haven't had any leaks since.
